ELM BT failure after Update 3.3
EnIgMa
Re: ELM BT failure after Update 3.3
Post by EnIgMa » 29 Oct 2011, 16:33
Ok guys just checked.
FES works great for me :)
I saw that it loaded the same settings from 3.2 and as i said, it communicates with ecu without any issue.
Besides, I got the recent cars erased.... so have you guys checked if your fes load the right device settings? maybe, for unknown reason it didn't have.
Post by Alfaeddy » 29 Oct 2011, 20:00
Thank you for your test
After his Belli29 wrote the ELM BT does not work after upgrading to 3.3, I tested my 5 pieces.
And one went down to the other four not??
Then I installed the new and much Tries to FES 3.2 RESET
installed, still nothing.
Only after he had been trying to go suddenly, and I know
why not?
Only with Belli and still others are still not working, BT ELM.
