can not connect with airbag ecu fiat marea '97
159sportwagon
Post by 159sportwagon » 27 Feb 2011, 15:51
hello, i can not connect FES with my fiat marea 1.6 16v . i try to reading the airbag ecu. i have no chance . i use the VAG/com kkl interface modified with the 3 pin adapter and the adapter cable 2. what I'm doing wrong?
cabal
Re: can not connect with airbag ecu fiat marea '97
Post by cabal » 02 Apr 2011, 22:44
I have the same problem with AIR BAG.
Nick_By
Post by Nick_By » 07 Apr 2011, 11:26
I'm can't connect to AirBag ECU too. Fiat Marea 1997 1.8 . multiecuscan can't read ECU Airbag. i use the VAG/com- USB interface modified with the 3 pin adapter and the adapter cable 2
Post by yani » 07 Apr 2011, 13:01
Earlier versions of Fiat Marea have Allied Signal airbag module which is not supported by Multiecuscan.
maunu
Post by maunu » 07 Apr 2011, 19:38
Can Alfa 156 Allied Signal Airbag ecu test be used for this?
