Problem Connecting Hitachi MPI injection (pre98)
Re: Problem Connecting Hitachi MPI injection (pre98)
Post by yani » 08 May 2011, 16:01
I will release version 2.8.2 tonight with fixed support for this Hitachi ECU..
byrrt
Post by byrrt » 09 May 2011, 15:51
yani - Thank you!
Last version works properly witch engine ECU:)
Best regards!
Peter
Ralf A.
Post by Ralf A. » 10 May 2011, 06:53
With 2.8.2 it is connecting with my '96 Fiat 1.8 Coupe.
Many thanks.
Ralf
ubohli
Post by ubohli » 11 May 2011, 05:47
Good Morning,
:? unfortunatly it still does not work on my barchetta '96.
Scan works, but connecting tells me check cable/interface.
I think, if the scan works, the connection cable->interface is correct, isn't it ?
What can I do ? System is VISTA SP2 and USB-KKl interface
wombi
Post by wombi » 11 May 2011, 09:22
Good day,
Which computer do you use? laptop or netbook? :?:
Greetings
wombi
delta-c
Post by delta-c » 11 May 2011, 18:35
2.8.2 works with a Lancia Delta Hitachi ECU '97. Great work :mrgreen: :mrgreen: :mrgreen:
Post by yani » 11 May 2011, 18:40
ubohli wrote:Good Morning,
Did you check the common problems like interface driver and driver lattency settings?
Espi
Post by Espi » 28 May 2011, 18:24
Marea 1.8 -00. KKL-cable (Lenovo T61, Win7 pro) & multiecuscan 2.8.2
Connect ok, but jums everytime when i open "error sceen" and multiecuscan need close with "taskmanager". I cannot clear error and see what is the new error code.
http://aijaa.com/v.php?i=005798110069.jpg (first and second erros is okay, but i need to see description "error 87")
Abbadon
Post by Abbadon » 01 Jun 2011, 06:38
Version 2.8.2 works perfekt with my 96 Barchetta.
Now I just wait for Airbag support.
Thank you
good job
Espi
Post by Espi » 01 Jun 2011, 19:58
Espi wrote:Marea 1.8 -00. KKL-cable (Lenovo T61, Win7 pro) & multiecuscan 2.8.2
Change KWP2000 timing to "Optimal" works and errors reseted.
