Alfa 156 2.5V6
Posted: 12 Jan 2011, 15:06
by devc
Hi Yani,
In FES v 6.2.1 the The Me 7.3.1 Engine ECU for the Alfa 156 2.5 V6 has dissapeared.
Can you please put it back. I can use the GTA's Me 7.3.1, it gives a ISO code fault, but is usable.
Thanks,
Regards,
Dev
Re: Alfa 156 2.5V6
Posted: 12 Jan 2011, 16:06
by yani
What do you mean?
It was there in previous versions and now disappeared?
Also, I think that 156 2.5 V6 has either Me 2.1 or Me 3.1.
Re: Alfa 156 2.5V6
Posted: 13 Jan 2011, 10:10
by devc
Hi Yani,
I am 99% sure it was there in previous versions of FES.
The Alfa 156 2.5 V6 24V from late 02 onwards,(so called facelift) had the Bosch Motronic Me 7.3.1 engine ECU installed.
The ECU was mounted on the plennum chamber and the car had a display panel on top of the dashboard centre,
combined with the airvent. They also had cats installed on the exhaust manifolds & 4 Lambda sensors.
Regards,
Dev
Re: Alfa 156 2.5V6
Posted: 13 Jan 2011, 10:54
by devc
Hi Yani,
I am realy sorry for wasting your time, I think old age brings brainfade.
You are 100% right, Me 2. & 3.1 for the 156 2.5v6
Sorry again.
Regards,
Dev
Re: Alfa 156 2.5V6
Posted: 22 Feb 2024, 11:54
by Nicklas L
I am reopening this topic because I canĀ“t really wrap my head around it.
I have a 156 2004 facelift equipped exactly as described above. Especially, I know for sure that it has 4 lambda sensors and the ECU on the plenum. However, when I connect (or simulate) using the 3.1 ECU-template (as suggested by MES), one of the lambdas is not present. Although, for the 7.3.1 ECU-template, all 4 lambdas are there.
So, either there is a bug with the template for 3.1, with one lambda not mapped, or this model actually has the 7.3.1. Else, I am missing something... Can someone bring clarity to this?
