Alfa 156 2.0 TS Selespeed ME 3.1 Breakdown
Agostinho
Post by Agostinho » 30 Aug 2010, 16:27
Hi Yani.
Every Time when i want to connect my ECU ME 3.1 the Connection break down after 5-8 sec.
On other ECU like ME 1.5.5 on the Alfa 156 2.0 TS of my daughter it works fine.
The Connection to the Selespeed is all right.
I have tried some other VAG KKl USB Cables, but it is always the same. The Connection breakdown.
I´m not the only one with this problem. Another Mate of mine got the same Trouble with his 2.0 TS 16V Selespeed ME 3.1.
What should be maybe the problem?
Thank you for answering, Ago.
edit: I use VAG KKL Interface
Re: Alfa 156 2.0 TS Selespeed ME 3.1 Breakdown
Post by yani » 30 Aug 2010, 18:09
Send me a report and I will check where the problem is.
That is the small red button "Send Report" on the bottom right in the main window of Multiecuscan. The button appears after disconnecting from the ECU.
Agostinho
Post by Agostinho » 31 Aug 2010, 10:44
OK Yani.
I´ll send you in the next Days the Report.
THX, Ago.
Agostinho
Post by Agostinho » 23 Sep 2010, 06:51
Hi Yani.
Today i have send you the Report.
Greetings, Ago.
Post by yani » 23 Sep 2010, 13:19
Thanks.
I saw the ME3.1 report and now I see where the problem is. Will be fixed in next release.
Agostinho
Post by Agostinho » 23 Sep 2010, 21:08
Super Yani.
This is one of the Reason why i bought your Program.
You fixed the failures so fast like a dessert storm.
I love to work with professionals.
THX, Ago.
Post by yani » 05 Oct 2010, 15:45
Can someone please confirm that this ME3.1 problem is fixed with version 2.5.
Post by yani » 10 Oct 2010, 14:14
Anyone to confirm that this ME3.1 problem is fixed with version 2.5?
sele156
Post by sele156 » 10 Oct 2010, 15:51
yani wrote:Anyone to confirm that this ME3.1 problem is fixed with version 2.5?
Sorry Yani , I wish I could but i can´t.
The VAG- Interface works fine with SELESPEED but still disconnects after a few seconds with ME3.1 even with Multiecuscan 2.5. Both the Motronic and Selespeed work fine with ELM 327.
Yours
Bernd
Post by yani » 10 Oct 2010, 16:51
Did you send report?
