It looks like the factors to calculate the injection timing are way off. You should get that checked...
Injection duration should be reported in micro seconds (roughly 0-2000us), and timing in degrees (-4 to +20 degrees BTDC), but FES reports some values that are way off...
EDC16 injection duration and timing
Re: EDC16 injection duration and timing
Thanks for reporting this. The scalling was wrong.
It is fixed now and will be correct v2.4.
