Proxi alignment failure
acgiannopo
Post by acgiannopo » 20 Jan 2023, 18:55
Good afternoon to you all.
I have an Alfa GT 2.0JTS 2004 model. I recently purchaced a new dashboard, a blackline which comes from the facelift model. Both panels are the selespeed ones. The panel works fine. However, we tried today to perform the proxi alignment procedure in order to stop the flashing odometer but didn't manage to. We (me and my mechanic) tried with MultiEcuScan v4.8 multiplexed via a CanTier usb cable several times. Kept responding that it failed due to system error. Unfortunately we didn't save a copy of the report in order to have more details. Any ideas? Is it possible to solve it someway?
shpuncik
Re: Proxi alignment failure
Post by shpuncik » 21 Jan 2023, 13:06
logs are saved in MES installation folder. check there.
acgiannopo
Post by acgiannopo » 24 Jan 2023, 17:11
shpuncik wrote:
21 Jan 2023, 13:06
Thank you. I will come back with details.
acgiannopo
Post by acgiannopo » 25 Jan 2023, 16:30
So, I'm coming back with the log from multiecuscan:
CAN CONFIGURATION DATA:
00 00 1D 6B 00 00 1D 6B 00 00 08 01 00 00 00 01 00 00 00 00
00 00 1D 6B 00 00 05 09 00 00 1D 6B 00 00 05 09 00 00 05 01
36 30 36 39 33 34 36 37 20 20 20 50 50 45 41 43 45 45 45 53 49 20 03 06 20 6B 1D 00 00 09 05 00 00 49 00 00 82 26 07
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Receiver Radio/Radio Navigator Node (NRR/RMN)
Driver Door Node (NPG)
Automatic Transmission Node (TCM/NCA/NCR)
Steering Angle Sensor Node (NAS)
(Multiecuscan 4.8)
1/20/2023 4:25:12 PM
Alfa Romeo GT JTS 2.0
Dashboard Node (IPC/NQS): EOL Failed
Receiver Radio/Radio Navigator Node (NRR/RMN): Ok
Driver Door Node (NPG): EOL Ok
Automatic Transmission Node (TCM/NCA/NCR): Ok
Steering Angle Sensor Node (NAS): Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (IPC/NQS) FAILED! - Configuration not supported by system error
Writing to module: Driver Door Node (NPG) SUCCESS!
FAILED TO EXECUTE
Hope this can help somebody to give me an idea of how to solv the proxi alignment issue I have.
Thank you in advance.
chrener
Post by chrener » 26 Jan 2023, 08:40
HI!
As you can see your dashboard has EOL Failed status...
So here is main problem.
Probably your BCM cant recognize this IPC type...
Try to flash your BCM unit with newest software if it is available...
And you will see...
acgiannopo
Post by acgiannopo » 01 Feb 2023, 23:57
chrener wrote:
26 Jan 2023, 08:40
HI!
And you will see...
Issue fixed with custom proxi procedure. :-)
No more flashing odometer.
chrener
Post by chrener » 10 Feb 2023, 08:03
what needed to be changed in custom proxi?
Byte number and value?
